Re: start switch on farmall
Posted by glennster on August 17, 2009 at 13:29:39 from (99.139.125.51):
In Reply to: start switch on farmall posted by wally b on August 17, 2009 at 13:11:28:
starter switch is prolly wore out. you can bypass the switch by using a set of jumper cables. gonna depend on whether you are 6v pos ground or 12v neg ground. if 6vpos ground, hook one end of the jumper cable to neg post on the battery and touch the other end to the post on the starter. that should get er to turn over. you'll need a heavy set of jumper cables. if 12v neg ground, hook jumper cable to pos terminal of battery, then touch other end to starter post.
