Re: start switch on farmall
Posted by Janicholson on August 17, 2009 at 13:37:24 from (199.17.6.60):
In Reply to: start switch on farmall posted by wally b on August 17, 2009 at 13:11:28:
If the studs on the back of the switch are open to shorting across, the jumper clamp is often easy to use as a bypass between the terminals. Also, if jumping as Glennster indicates, using both jumpers to jumper the battery to the starter will carry twice the current as one. JimN
