Re: start switch on farmall
Posted by NDS on August 17, 2009 at 14:37:57 from (205.188.116.73):
In Reply to: start switch on farmall posted by wally b on August 17, 2009 at 13:11:28:
If you decide to use Janichlson's and glenster's method be carefull and triple check to be sure tractor is out of gear. I know of several in graveyard that were put there by starting tractor from ground and being run over or pushed through wall. Have had a couple of close calls myself.
