Posted by Hugh MacKay on August 17, 2009 at 16:44:50 from (209.226.247.59):
In Reply to: Re: Super A-I posted by Red Mist on August 17, 2009 at 15:52:13:
Adrain: I'll try not to confuse this. Super A-I were built during the entire production run of Super A, from 1947 until 1954. Super A-1 were built in 1954 after serial number 356001 and there were only 1957 built. I understand, and I'm not certain if this is accurate, only two of those 1957 tractors were Super A-1-I.
All Super A's prior to 356001 came from factory with C-113 engine, however all of those engines can be changed to C-123 or 3-1/8" bore.
Mike is right on the quickest way to spot a Super A-1 or A-1-I, because of the higher radiator, the fuel tank is close to 2-1/2" above the touch control unit. Regular Super A is only about 1/2" clearence between tank and touch control.
Good luck if you acquire a Super A-1-I, you'll indeed have a very rare tractor even if more than two were built. By the way, on a Super A-1 or A-1-I, the model number stamped with engine serial number will FMC and the numbers will be same sequence as Super C. First Super A-1, serial number 356001 had FMC engine number 206628. This information comes from IH records, not Tractor Data or what someone wrote in a book for profit rather than accuracy.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
