Re: Farmall H more oil pressure problems
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by justin on April 18, 2000 at 05:08:53 from (209.83.211.25):
In Reply to: Farmall H more oil pressure problems posted by Jim Radley on April 17, 2000 at 21:41:04:
Did you check the tolerance of the new bearings?? If they were between 1-3 thousandths, you are okay, otherwise you may need to have the crank reground.. The oil pump situation sounds bad, so you may want to get a replacement and see what happens.. One thing that has happened in one of my tractors, is that the cam bearings were worn out so I replaced them..
Post A Followup
: Re: Re: Farmall H more oil pressure problems
