I wouldn't put a torch on the pistons. Try putting the piston into varnish/gum remover cleaner for a few days. If you have access to an ultrasonic cleaner, put the pistons and heated cleaner in and let sit for a few hours.
You may have to repeat this a few times. Be patient.
The issue with a torch or oven is that you're heating both the piston and the rings at the same time, which doesn't do you a lot of good as far as forcing the parts apart. The downside is that you might easily distort the piston if not heated correctly with a torch, and you need some way of anchoring the piston so that you can put leverage against the rings. If the piston is aluminum, you run the risk of damaging the ring grooves trying to pry the cast iron or steel rings out.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
