Re: How to loosen stuck piston rings(IH 400)
Posted by old on August 17, 2009 at 21:02:42 from (4.245.6.157):
In Reply to: How to loosen stuck piston rings(IH 400) posted by SDE on August 17, 2009 at 18:48:50:
Fill in the blanks!! Is the piston in or out of the engine??? Parts cleaner is not a lube and is only a cleaner so NO it will not do much. As for heat ya it will work because you will need new pistons after you do that. ATF and soaking is probably the best and if you need a pan with ATF and about 200-250 degrees in and oven no hotter
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
