Re: Farmall A piston weights
Posted by Janicholson on August 18, 2009 at 06:47:54 from (199.17.6.60):
In Reply to: Farmall A piston weights posted by TWheat on August 17, 2009 at 16:14:10:
I'll ad to Glennster's comment.
The crancks in many inline four cylinder engines are of the two up, and 2 down variety. This has no intrinsic ballance, but depends on the mass of the system to be uniform to keep vibration to a minimum. Though the actual weight of the piston is not critical (within reason), the uniformity between the pistons is very important. If the two up pistons weighed more than the two down pistons there would be pretty radical vibration. Imagine a barbell with a half pound missing from one end.
Thus the use of a cast iron piston set in early engines could be as smooth as a set of aluminum pistons in a replacement set without any ballance problems, and no changes to the crank or pulleys or flywheel. JimN
