Re: Farmall H dual wheels
Posted by sflem849 on August 18, 2009 at 10:42:00 from (66.254.196.101):
In Reply to: Farmall H dual wheels posted by ryanwheelock on August 18, 2009 at 07:57:02:
I have seen it done quite a bit the way they are describing. I have heard they tend to clog up easily. If you are clogging up duals you shouldn't be out there moldboarding anyhow.
Just so it is said, you should really only run a dual on the onland side.
