Re: 560 diesel - injector pump
Posted by jdemaris on August 18, 2009 at 11:11:08 from (67.142.130.12):
In Reply to: 560 diesel - injector pump posted by Tractordummy on August 18, 2009 at 09:03:59:
Yes, there is a special tool. It's just a simple, hand-held compressor. Stanadyne part # 13371. You could buy new for $5 at the following, but I haven't checked lately.
If careful though, you can do without it.
On many applications, the Stanadyne pump uses a bronze-bushing in front where those seals ride. It gets a ridge worn into it over time. Once the ridge is there, the bushing needs to be replaced (cost $10). If not, it's pretty hard to get the seal in without flipping it over.
Not sure about the IH application. Some companys order that pump with a steel bushing instead of bronze.
http://www.thompsondiesel.com/Stanadyne.htm
