Posted by mkirsch on August 18, 2009 at 12:07:26 from (64.80.108.57):
In Reply to: 140 no compression posted by Brad M-C on August 18, 2009 at 11:38:49:
It would make sense that he is FILLING the cylinders with oil.
A tablespooon of oil in each cylinder would not bring the compression up to 150PSI from ZERO. Not in a million years.
The only way you'd get that much improvement is if you FILL the cylinders with oil. Even if a valve is stuck open on each cylinder, the oil pumping out would create a good amount of pressure for one revolution.
I gotta wonder how much oil blows out the exhaust. It must make a HUGE mess.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
