Re: Farmall H dual wheels
Posted by glennster on August 18, 2009 at 16:19:13 from (24.14.63.246):
In Reply to: Re: Farmall H dual wheels posted by ryanwheelock on August 18, 2009 at 09:25:16:
just curoius, how much weight are you running on the rears? prolly need at least 2 cast weights on each back wheel if your pulling a 3 bottom. may even want to consider loading the back tires for ballast, then you wouldnt need to dual her up.
