Re: Saginaw 3pt hitch on SMTA
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Llama Todd on April 18, 2000 at 07:01:01 from (216.160.0.154):
In Reply to: Saginaw 3pt hitch on SMTA posted by Mike k on April 17, 2000 at 18:43:31:
I have two M's. I have put a Worksaver 3-pt hitch on one and a Saginaw 3-pt on the other. I have been happy with both, but probably prefer the Saginaw hitch. It comes painted Farmall red and includes two cylinders. The Saginaw comes painted black and didn't have any cylinders. The control arms are adjustable on both models and will drop very close to the ground. The Saginaw hitch maintains the swinging drawbar. The Worksaver does not. I have a steel bar with holes drilled in it that I use for the Saginaw when I want to pull a haywagon, etc.
Post A Followup
: Re: Re: Saginaw 3pt hitch on SMTA
