Re: farmall hydraulic lines
Posted by mattofvinings on August 19, 2009 at 03:19:08 from (198.208.159.20):
In Reply to: farmall hydraulic lines posted by Matthew Webb on August 18, 2009 at 20:39:45:
If the new tube can be fabricated I would still consider brazing.
To butt-join two tubes I'd find the next size of tubing and make a sleeve - similar concept to copper sweat-solder coupling, although I would use steel.
If you have to go back to the end block on the pump, I'd carefully bore or ream the block for a very close fit (tap fit, very slight press) and then braze. Tig welding is always a possibility (the demo pieces are out there of aluminum pop cans and gum wrappers tig welded together) but a greater skill level would be required...brazing is going to be a process that's much more forgiving with a thin section in my opinion.
