Re: caM geAR PRICES?
Posted by glennster on August 19, 2009 at 06:02:53 from (99.139.125.51):
In Reply to: caM geAR PRICES? posted by tn terry t on August 18, 2009 at 17:06:46:
i have a friend that owns a custom gear shop. many of the aftermarket gears are made overseas, or, the blanks are made overseas and final machining done domestically. his shop either uses domestic produced blanks and then he does the machining, heat treating , hard chroming ect, or if a suitable blank is not available, they hog the blank out from a billet and build the gear from there. probably a stock application will get along fine with an import gear, but if it is a severe use, ie puller or hot rod, the domestic gear would be the better choice. big problem is going to be cost. import gears are quite a bit lower cost, mainly due to labor costs.
