Re: 140 no compression
Posted by NawlensGator on August 19, 2009 at 08:53:05 from (52.129.8.47):
In Reply to: 140 no compression posted by Brad M-C on August 18, 2009 at 11:38:49:
I don't think it's possible to have suction at the carb and then zero pressure in all cylinders. My 140's have 150 psi compression on all cylinders without using oil. Your missing something.
I had lower pressure once because the gauge fitting wasn't seating in the plug hole. Had to ream out (18 mm) the threaded hole and then I got pressure. I bet it's something real simple.
