Re: Lights won't wor on Farmall Cub
Posted by gene bender on August 19, 2009 at 11:09:37 from (67.55.227.88):
In Reply to: Lights won't wor on Farmall Cub posted by jamesdwight2 on August 19, 2009 at 10:43:51:
You need a little meter and check for volts and ground doesent seem that all would have a bad ground but its possible. Just follow the voltage from the sw to the lite and you will find it. If you read batt volts at the terminal then you have to take the lite apart and follow up.
