Re: hand crank starting mechanism
Posted by rustyfarmall on August 19, 2009 at 11:20:50 from (209.152.78.140):
In Reply to: hand crank starting mechanism posted by farmallboy15 on August 19, 2009 at 08:37:27:
You will have to get it freed up before you can remove it, and once it is freed up it will then function as intended and there will be no need to remove it. Just spray it down with PB Blaster or whatever your favorite flavor of penetrating oil is and be patient. Every so often, tap on it with a hammer. It will come loose.
