Re: Farmall H Transmission Noise
Posted by Janicholson on August 19, 2009 at 14:17:29 from (199.17.6.60):
In Reply to: Farmall H Transmission Noise posted by Alakshak on August 19, 2009 at 13:37:21:
A partially disassembled coupling at the clutch shaft would do it. as would a coupling assembled with the drive spider backwards. A sticking chattering clutch will also make the sound/vibration.
I believe it can be fixed W/O splitting or tearing into the trans. Pulling the belly pump and inspecting will tell the tail. JimN
