Check the fuel flow to the carb., by disconnecting the line at the carb and drain out at least a quart or more. Is the fuel flow a steady stream or does it start to slow down? It could be the vent in the gas cap. The screen in the sediment bowl could be partially blocked. Can you drain the gas out of your tank and then remove the entire sediment bowl assembly from the tank. Mine was partially plugged and would not allow enough gas through it. Do you have an inline filter? Some cause a problem. Remove it. The inlet to the carb may have a brass screen in it. It should be attached to the fuel line, but maybe it broke off and it is stuck in the carb an it could be plugged. SDE
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
