Re: Farmall H Transmission Noise
Posted by Alakshak on August 19, 2009 at 17:57:34 from (69.208.89.23):
In Reply to: Re: Farmall H Transmission Noise posted by sflem849 on August 19, 2009 at 17:54:39:
He's talking about that spacer that has the 4 press fit bolts thru it connecting the drive shaft to the transmission. I do believe I had it backwards, most likely this is what caused those clutch bearings to go bad. If it's backwards the drive shaft wont have a strong fit in the flywheel causing slop. I've found this out the hard way.
