There is a engine vent line that comes out beside the valve cover and goes to the air cleaner intake pipe. If it has the a IH A type injection pump there's a vent line from it up to a filter screwed into air intake line. If one of those is what you mean, There's a problem if collant is in it. Several frame rails with a few little changes were made. Some will work on gas and diesel and a lot won't. Diesel is the only engine that uses the front support. There's very little movement between support and front engine cover. Most haven't saw grease in years. Most have shims between the top of frame rails and front engine support. Original rails were only welded at the rear mounting flanges.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
