Re: SWD6 won't start.
Posted by mkirsch on August 20, 2009 at 05:18:18 from (64.80.108.57):
In Reply to: SWD6 won't start. posted by Todd L on August 19, 2009 at 20:08:03:
On any tractor that was simply driven to a spot, shut down, and left for X years, the MINIMUM you need to do is:
1. Drain all old gas and rinse out the gas tank with fresh gas.
2. Remove the carburetor, clean THOROUGHLY, install rebuild kit.
3. Replace points, condensor, rotor, cap, wires, and plugs.
4. Change the engine oil and filter before you even turn it over.
5. Remove and clean all heavy battery cable connections.
6. Charge battery.
Feel free to add anything I might have missed.
You can fiddle all you want but in the end you will end up doing everything I listed above to get the tractor running right, and probably more.
