Re: How to loosen stuck piston rings(IH 400)
Posted by JT on August 20, 2009 at 06:32:42 from (70.226.202.103):
In Reply to: How to loosen stuck piston rings(IH 400) posted by SDE on August 17, 2009 at 18:48:50:
I had an H that had rings stuck...really tight. I put the rod in a vise, took a small punch and chisel and slowly worked them you, a little bit at a time. The finally came out. If they are stuck in the grooves, just buy a set of new rings. More than likely the rings will not seat real well after being stuck for so long.
Jim
