Re: Cub fuel flow question
Posted by Janicholson on August 20, 2009 at 06:38:19 from (199.17.6.34):
In Reply to: Cub fuel flow question posted by Rodger In Sabula on August 20, 2009 at 05:29:56:
With the bowl on and tight, the rate of filling is not going to point to a problem. Remove the bowl and fill a can held under the fittings. It should flow a pint in less than 30 seconds. A good solid soda straw of flow. If it does, the down stream lines need to be checked. There is a screen at the carb inlet that must be clean. If it flows out the carb fitting into a can at the same rate, then that is cool. It should flow out the inlet of the needle and seat in the carb at about 1/2 pint in 30 seconds or more. Good luck, JimN
