Re: HOT COIL
Posted by Bob Kerr on August 20, 2009 at 14:39:54 from (216.249.83.172):
In Reply to: HOT COIL posted by Bonnie Tallman on August 20, 2009 at 14:26:47:
If you are wiring it up with straight 12v then you may need a ballast resistor in line with the 12v input to the coil. Also if you leave the coil hooked up while tinkering and the points are closed, it will get hot for sure. One more question, was the tractor converted to 12 or did you just put a 12v batt and coil in and call it good?
