Re: Cub fuel flow question
Posted by Tom Fleming on August 20, 2009 at 14:46:14 from (67.20.240.67):
In Reply to: Cub fuel flow question posted by Rodger In Sabula on August 20, 2009 at 05:29:56:
Sounds like a sticky float to me. when it starts to sputter and "search", try pulling the choke out 1/2 way or so. If it smooths out again, take the handle end of a small hammer and moderately tap the sides of the float bowl on the carb. if it will run smoothly with the choke off after that, you definately have a sticky float or needle valve.
This of course is after you have determined you have good flow into the carb.
IMHO.
