Re: HOT COIL
Posted by ScottyHOMEy on August 20, 2009 at 15:07:41 from (71.241.214.214):
In Reply to: HOT COIL posted by Bonnie Tallman on August 20, 2009 at 14:26:47:
You need to check out Bob's idea about the resistor and whether or not your coil needs one.
More to the point, if your condenser is hooked up as you say, it's wrong. If you are set up for negative ground (battery - to chassis) the + terminal on your coil should be connected only to the hot lead from the battery/switch. The wire connected to the - terminal on the coil should run down to the distributor body and connect to an insulated stud on the outside of the distributor body that conducts the juice to the points and condenser, which are connected together inside the body to the inside of the stud.
You've either got the condenser in the wrong place, or what you're looking at is not a condenser.
