Re: 706 hy-tran leak
Posted by Chuck's Repair on August 20, 2009 at 18:58:23 from (162.40.106.144):
In Reply to: 706 hy-tran leak posted by Ken from Mich on August 20, 2009 at 17:06:37:
There were two different fill tubes used on that tractor. The early serial number tractor had a short fill tube and the later tractors had a longer fill tube. I don't know why the change but oil leakage may have been the reason or part of the reason. if you have the long tube and someone replaced the dipstick with one for the short tube then your HY-TRAN would be way over full however that is unlikely because the dipsticks were designed differently and the early dipstick would extend above the deck plate.
Chuck
