Posted by Nick Lenarz on August 20, 2009 at 19:25:23 from (75.104.184.224):
In Reply to: HOT COIL posted by Bonnie Tallman on August 20, 2009 at 14:26:47:
Ditto on the ballast resistor. I got mine from an auto parts store, ask for a "Ford ballast resistor" and most places will know what you mean. They"re 5-ohm, 50 watt ceramic resistors, and are made to mount right to that little "ear" on the coil strap. I had similar trouble with my M"s coil overheating, and after I installed the resistor, no more problems.
6-volt and 9-volt coils were in use in cars even up to the mid 80s- both our "82 Jeeps had them, and used dozens of feet of resistor wire instead of ballast resistors.
If you want to do away with the resistor issue altogether, look into converting to an "e-frame" coil such as out of a 90"s Ford or Jeep. They"re true 12v, smaller than a can-style coil, and give a hotter spark for better combustion. Takes away coolness points as it"s obviously not factory original, though.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
