I cleaned the switch box and seem to get some charging. If I turn the switch to high charge it shows a small charge on the amp meter. At low chaarge it shows nothing. If I turn on the lights I show a discharge and it doesn't come back to a charge after running for several minutes. If I slowly turn the lights from dim to high and back to dim I show a good charge half way between. I do not get 7 volts at the battery however. I took off the gen bracket and cleaned the block and gen bracket to make sure I have a good ground there also. It is a new battery so maybe it won't show a charge on low but it should with the lights on shouldn't it?
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
