Re: IH 544 TA
Posted by Hugh MacKay on August 21, 2009 at 02:59:44 from (216.208.58.150):
In Reply to: IH 544 TA posted by Carlton Burnett on August 20, 2009 at 15:35:25:
Carlton: Why should you be more concerned about TA than any other part of tractor. It's 35-40 years old and if it was used a lot the whole damn thing could be worn out. You should be able to check TA if the brakes are good. Even if bad, TA will cost a max. of $1,200. Hell, if you end up needing PTO clutches, main clutch, rims, radiator hydraulic pumps, etc. those could cost a whole lot more than $1,200.
