Re: Farmall Cub snow blade fitting/converting to a Farmall A
Posted by Brownie 450 on August 21, 2009 at 04:09:28 from (66.43.241.141):
In Reply to: Farmall Cub snow blade fitting/converting to a Farmall A posted by gocartbuilder on August 20, 2009 at 11:47:56:
If you can weld & have some steel laying around, you can fab up brackets quickly. It might not snow this winter.
