Posted by tbraley on August 21, 2009 at 06:09:27 from (67.142.164.24):
I have a manual that tells you how to bleed the system, it says:
"To bleed the system, fill reservoir to the bottom of filler hole then start engine and cycle system until any air is bled from system. Recheck reservoir fluid level and add fluid as required"
Now I am NEW to this so this may be a stupid questions. I had to change a hose for the back hoe and now it works very slow and is very week.
It says to fill to the bottom of filler hole, Where is the "bottom of filler hole"?
Do I take the filter out to see this?
I filled the Hydraulic tank up and started the engine. I had left the cap off and nothing would work. When I screwed the cap to the Hydraulic tank back on the hoe would work but was slow and weak.
Now I had to unscrew 3 lines that go under the hoe seat to change the new line. So I assume air is in the lines.
The direction really don't make any since to me. Can any help me on bleeding the system?
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
