Posted by Jim Becker on August 21, 2009 at 14:13:04 from (173.57.157.82):
In Reply to: 240U 3 point posted by IH fan on August 18, 2009 at 15:04:36:
I've seen pins sheared off so cleanly that the broken part fills the hole and makes it almost impossible to see. That seems unlikely in this location, but are you sure there isn't a hole in #1 that is filled with a broken pin?
The limiter (#2) is supposed to pivot (front to rear) on the 2 pins that attach it to side plates (#4, #13). You should be able to move it until the ends of the straps (#15, #16) line up with the eye-bolt. The limiter has to pivot for the ends of the straps to follow the radius of the eye-bolt as the lift is run up and down. Could the limiter have been welded to a fixed position? Maybe by the same guy that welded #17? If so, the eye-bolt probably broke the first time he raised the hitch after he welded it. You can probably have a new eye-bolt made, but it may be the least of your troubles.
The rear weights for that tractor were split type. But one-piece weights from an A or B will bolt right on (at least if you have standard type 24" wheels) and should be easy to find.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
