Re: Farmall Cub snow blade fitting/converting to a Farmall A
Posted by gocartbuilder on August 21, 2009 at 15:35:44 from (209.40.212.229):
In Reply to: Re: Farmall Cub snow blade fitting/converting to a Farmall A posted by James Rumph on August 21, 2009 at 14:17:10:
Happens I have two friends who work for the local road commissions for two different counties as head of maintenance of the trucks. Think I will give them a call. Thanks for the advice.
