Posted by Roger46 on August 21, 2009 at 18:17:48 from (70.215.250.125):
In Reply to: PTO Generator posted by Alakshak on August 19, 2009 at 18:12:39:
I have a 15kw PTO generator I bought at an auction several years ago. I have used it on several of my tractors including a B, Super C, Super H, and MD with no problems. I have never had to run it for any extended time like for days, usually only for hours. The main problem with using a tractor for extended periods of time on a generator is similar to when our neighbor used to use a tractor on an irrigation pump. If the engine overheats or loses oil pressure the engine with self distruct if not monitored. Generator engines have low oil pressure and overheat shutoff switches to prevent this. If your H doesn't use any oil you will probably be OK just checking it every time you fill up with gas. Roger
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
