Re: Oil Leak in Rear of A
Posted by ScottyHOMEy on August 22, 2009 at 14:38:03 from (70.105.241.177):
In Reply to: Re: Oil Leak in Rear of A posted by Tom in Iowa City on August 22, 2009 at 12:26:45:
Following up on what the others have said, it's not hard for that transmission to get over full.
If it's condensation or rainwater getting in, try the drain plug first after the tractor's been sitting a while, and see if you get water.
The other thing that wil overfill them is to put the full 5+ quarts of gear oil in when there's sludge taking up space inside. Then you're over full again, and perfectly good seals will leak.
Try draining it down some. Replace the drain plug and refill just to the level where it starts to run out the hole for checking the level, and see if that doesn't stop the leak.
