Re: Oil dripping from hole in bottom of clutch casing
Posted by dave2 on August 23, 2009 at 02:15:31 from (139.139.35.70):
In Reply to: Oil dripping from hole in bottom of clutch casing posted by Jim Good on August 22, 2009 at 14:06:41:
What color is it? If it's black, good bet it's the rear main on the engine. If it looks cleaner and a little thicker, frt seal on trans.
If it was me: (disclaimer)
Rear main, I would change the oil and add a bottle of stop leak with the fresh oil (don't overfill). Make sure that the PVC system is not clogged.
Trans seal, make sure you're not over full and that vents are free and live with it until it gets out of hand.
Dave
