Re: can I run an 8 volt battery in Farmall M?
Posted by John T on August 23, 2009 at 06:02:53 from (66.244.97.31):
In Reply to: can I run an 8 volt battery in Farmall M? posted by TJ m on August 23, 2009 at 05:24:29:
Thers a good chance YES it will be okay, butttttttttttt that depends on what charge control system it currently has:
If its a simple 2 wire Cutout Relay and LHBD light switch, it will still charge ALTHOUGH NOT AT ANY SUPER HIGH RATE
If it has a Voltage Regulator that uses a "current" regulated field control relay YES it can still work
If it has a VR that uses a "voltage" regulated field control relay IT NEEDS ADJUSTED
Why can it still charge?? basicaly a DC Generator dotn know what its output voltage is to be specifically, it increases EITHER if it turns faster ORRRRR you pump more current through it Fields, which is what the VR regulates.
IM NOTTTTTT A FAN OF ODD BALL JURY RIGGED 8 VOLT SYSTEMS. Its a band aid approcach to fix the real problem. On 6 volt I recommend use of the absolute biggest heaviest highest rated battery that will physically fit,,,,,,,,00 Gauge battery n starter n ground cables
Thats my story n Ima stickin to it
John T
