Re: can I run an 8 volt battery in Farmall M?
Posted by old on August 23, 2009 at 10:02:16 from (4.245.4.171):
In Reply to: can I run an 8 volt battery in Farmall M? posted by TJ m on August 23, 2009 at 05:24:29:
Simple answer is yes but in the long run at best it is a band-aid fix for other problems. 6 volt system have worked for decades and do so now. Big problem with an 8 volt battery is have you ever seen an 8 volt battery charger in the stores????????????? So if you put one in how do you charge it. Plus your 6 volt system at best unless you have some mods. made will only charge that battery to 7 or so volts so then you still are not better off. Stay with 6 volts or switch to 12 and be done with it
