Blind, in this case, means the hole is not a through hole. The casting was made extra thick at that point to assure sufficient depth to drill a pilot hole, then tap the hole (probably with a normal tap, then a plug tap to chase the threads almost to the drill bottom angle. Putting a cork only into a trans housing with oil on the other side is usually not done. If it is into a dry torque tube, No real issue. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
