Posted by Janicholson on August 23, 2009 at 15:26:36 from (64.61.211.148):
In Reply to: manifold questions posted by Rossputin on August 23, 2009 at 13:09:26:
Rust is to be found on all cast iron exhaust manifolds. If you clean it to metal, and have it ceramic coated (never done to tractors, but found on some Jaguars and other high end cars) it would not rust. If it is so rusty that big flakes are chipping off, a minor wire brush is OK, but I would not get carried away. The tubing and muffler are just steel. They also rust soon after ownership begins. If rusted out, replacing with stainless steel is expensive, but last a lifetime. A small diameter rotar7y wire brush will work, but do not get material flakes or wire pieces down it holes, They can cause instant knocks and ring land collapse when the piston tries to compress a solid. Blowing a heavy blast of air through the spark plug hole through the open exhaust valve and out the open port. (requires doing each several times and getting the valves open fully when doing it because particles go everywhere). JimN
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
