Re: Hyra Touch Controler
Posted by Janicholson on August 23, 2009 at 17:42:15 from (64.61.211.171):
In Reply to: Hyra Touch Controler posted by adrian on August 23, 2009 at 16:29:47:
Two of the most probable:
THe lever is getting worn at the splines of the shaft in the valve. It happens a lot. If the valve is not going all the way into the down position, it will act that way. There could be a stone or dirt in the slot the lever runs in (been there)
A third possible is a restrictor (one way) could be in the hose or coupling. JimN
