Hi, the normal place to tap into the hydraulics is by removing the hydraulic tube that goes from where the remote hyraulic controls would have been to the draft control mechanism at the back of the seat. The tube is somewhat of a "L" shape. To access this tube requires lifting up the platform the seat is connected to. The inlet side of a valve spool would connect to the front right where the tube was connected and outlet of valve spool connected to inlet of draft control where tube was removed. Sometimes the inlet of the draft control is capped and the outlet of spool valve is plumbed into transmission drain plugg under the right axle.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
