Re: what about the M?
Posted by James Rumph on August 24, 2009 at 04:15:21 from (24.192.125.175):
In Reply to: what about the M? posted by Bob S. on August 23, 2009 at 19:37:00:
If you drain the radiator there will still be water in the block that can freeze and crack her.
Can you get some one to put antifreeze threw the system.
How about lets find some help and get the lean out of the shed ! Come on folks didn't people used to help each other in time of need.
I'm in the south east part of Michigan and will help if you not real far.
