Re: How big can you bore a 350 Farmall
Posted by Dave S. on August 24, 2009 at 12:01:55 from (208.92.169.136):
In Reply to: How big can you bore a 350 Farmall posted by Matt Kaiser on August 23, 2009 at 20:40:42:
I completely overhauled a 300 engine,using 350 sleeves and pistons,300 carb & manifold, electronic ignition and installed in a H.
I think going any bigger is asking for transmission and final drive problems if it is going to be used in the field with a heavy load.
If you are going to use it for tractor pulls go to the pulling form. You should find the answers you need there. Good luck
