Re: Cub Hydraulic Pump
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by CLARK on April 18, 2000 at 14:18:00 from (205.188.193.33):
In Reply to: Cub Hydraulic Pump posted by Scott on April 18, 2000 at 10:39:54:
NO SCOTT, THE GROOVE IN THE HYDRAULIC PUMP SHFT IS NOT SUPPOSED TO BE THERE.THE GROOVE IS CAUSED BY THE OLD SEAL THAT WAS MADE OUT OF LEATHER.I ASSUME THAT YOUR REPLACEING THE SEAL BECAUSE OF HYDRAULIC FLUID LEAKING INTO THE CRANKCASE.IF YOU REPLACE THE SEAL IT WILL STILL LEAK BECAUSE OF THE GROVE IN THE SHAFT, YOU WILL HAVE TO REPLACE THE SHAFT TOO.
Post A Followup
: Re: Re: Cub Hydraulic Pump
