Re: F-20 flywheel installation
Posted by J.J. from Afton on August 24, 2009 at 20:52:28 from (66.41.82.17):
In Reply to: F-20 flywheel installation posted by kglo on August 24, 2009 at 09:25:00:
I have heard of people using heat, in that they heated to around 400*F in an oven so than it would slide right onto the crankshaft. Others I have heard of making a tool like the one you are talking about for I have no idea of where you might find one. The way I put mine on my Regular is rather frowned upon as it places a large horizontal load on the ball bearings holding the crankshaft. Mine I used assembly lube on the flywheel surface, than started it almost halfway on with a rubber mallet. Than I used a series of bolts and large washers and spacers threaded into the tapped holes (the ones that hold the flywheel housing) on the block to pull the flywheel on. I had no trouble as long as it is pulled evenly, like mine i only did 1/2 turn on each bolt and went around in a circle. Than using a large tap i ketp the two half circles lined up for the lock pin. To get the pin in I used assembly lube than threaded it onto the end of a slide hammer and it went in pretty easy.
Hope this helps you
-Jordan
third party image
This post was edited by J.J. from Afton at 20:54:54 08/24/09.
