Posted by Shane Green on August 25, 2009 at 14:28:49 from (75.121.53.169):
In Reply to: B275 pto disengages posted by Shane Green on August 25, 2009 at 11:59:22:
ok, I adjusted the 3 cap screws to .090 clearance. The pedal is a lot stiffer now, but the pto clutch still isn't working.
I noticed that the engagement lever starts 3/4" past the detent and when you get it engaged it's past the rear detent and up against the rear axle housing. I don't know if this was from the bolt clearance or adjusting the pedal travel.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
